pishta
I know I'm right....
lots of discussion about the 'Formula S' badge on the front fenders. 2579442 has horizontal studs, 2579443 ('66-) has vertical studs as only difference. Seems every place that sells the '65-68' repop is the 2579443 model but we got the side by side pins. Can owners of the 65's chime in and tell us what style they have? Seems 2 '65 literature sources call out the 443 part, one of them is dated 9/64! No need to remove, just feel behind the fender for horizontal or vertical nuts. Also give us the build date if possible too. My 4-1-65 build date had horizontal pin 442's. The diff is a slight blow of the '442s to follow the curved '65 fender but its so slight that a flat 443 would fit with the slightest gap on top and bottom. '442 still had a slight gap. Thanks!
