'66 Barracuda rear window regulator Qs
1974DartSwinger
Detroit, MI
Hey guys! I finally got around to tearing into my '66 Barracuda formula S windows last weekend. Found out that my drivers rear 1/4 window regulator had the cross arm broken in half. That explains why it wouldn't work!
Question: Which year car regulators will work for me? I'm assuming only A-bodies but anything other than the barracuda? I know the '66 is an odd-ball year car. I'll try to get some pictures posted of the regulator soon if that'll help.
One more quickie, I got into the front windows to lube the window tracks since they needed waaay too much effort to roll up/down. Got them both like butter now with some grease and a little oil in the regulator/crank.
My passenger window is nice and solid, no wiggles or wobbles. The drivers door is not. It is pretty darn floppy and when rolled up I was playing around with it trying to see what was going on. It seems the bolt/pin/rivet that hooks the metal that cups the window and attaches to the regulator arm was loose. I tried playing around with the adjustments of the window tracks but that didnt make any difference.
Any ways to tighten things up? I bugs me that the drivers window is so loose and it doesn't seal tight against the rear 1/4.
Thanks!!
Oh and update: the Mopar electronic ignition is working great! Got it set up 12* advanced and shes running really nice. Did about a 500 mile road trip for memorial day weekend. Man I love this car! Now that my Carter strip kit and eddy air fuel gauge is here its time to fine tune that carb :)
I've a quarter glass regulator for sale if you need one. The door glass probably needs new weatherstripping and adjusting to get it tight again. If the glass bracket is loose because of the plastic rivet, you may have to change that also. There should be a piece of rubber between the glass and the bracket. PM me with your shipping address and I'll get you prices.
Thanks, Mark
