66 Barracuda trunk prop rod trim ?
spopdil
Member
Dillsburg, PA
Hi, I have a 66 Barracuda that was restored. Where the trunk prop rod attaches at the trunk and 1/4 panel is there a piece of trim attached at these two points? There are 2 holes at each point and it looks like something is missing. Does anyone out there have these pieces? Thanks, Steve
Ooohh, very hard to find. I may be able to get a pic of that part on my dads 66 Cuda, if I remember correctly, you don't have to have the part, it is sort of a way to lock the hook in the trunk lid, it should still work fine without it. The piece is small, made of metal, you could probably make one. I will see about a pic and post one if I can, may be a couple of weeks before I see his car.
