66 dart AC parts wanted
66Dvert
Working on my custom car parts again!
Webster , florida
I just got the Airboxes and inside assemblies from a member here (thanks Tubar/John, parts are AWESOME!) and discovered I need some extra parts to finish up my conversion to a factory style (inside the car) A/C system
I'm looking for
blower motor resistor @ 2521544
and evaporator switch 2521624
and I think it's called an
air conditioning and heater bypass switch. the one I have goes on the top and I couldn't find a number on it
or workable /equivalent replacements from later years (this setup is 65)
blower motor resistor needed for MY A/C conversion
Ac and heater bypass switch also needed for MY conversion
and last but now least the Ac evaporator switch. , it's broke on the new A/c boxes I have for the Wife's dart.
or point me to a place to get those parts along with the engine bay valve that will work (I was thinking of robbing one from an 80's cordoba) will that work? I'm thinking it's just a valve that lets the coolant just circle back to the block if I'm using A/c instead of heat and opens for heater use?
