66 Dart instrument cluster removal
GTGrinly
Central PA
Attempting to remove instrument cluster, removed light switch, wiper switch, ignition switch, two screws on the left side and couldn't locate anymore and it don't budge....don't want to break it. any help is appreciated.
remove the cigar lighter and there are too more under the panel on the right like on the left.. just slide it out of the way.
then remove the speedo cable and the dash light pluges
all in all you have 5 things to unhook and 4 screws.
i know since i have pulled mine out 500 times
Cerwin
