[WANTED] 66 Tail Light Bezels
  • Thread starter Deleted member 38666
  • Start date
D
Guest
Thanks ahead,
Looking for a nice set of driver's side tail light bezels for a 66 Dodge Dart GT. I have
good lenses, just need the chromed pot bezels. Must be able to be buffed/shined to nice.
PM me at Old Dart 66. Thanks
Thanks ahead,
this are really hard to come by in good shape. the reason you can get semi decent passengers side ones is that the exhaust pipe was mostly on the drivers side and it messed up the bezels. /6, 273 2bb, I know my 65 dart original hi performance 273 4bb was single exhaust on the drivers side also and I think the dart charger was on that side too. duals ran out to the back messed up all the bezels, but that was a non factory setup
I'm getting mine re-chromed After I fix all the pits in the 2 drivers side bezels. I got a couple of "quotes" without fixing the pits and letting them do it for over 450.00 plus per bezel from 4 or 5 shops I sent pictures to. I'm getting the bezels de-chromed for 30.00 per bezel and then buying "muggy weld" and fixing my pits, sanding to 1500 in stages and making sure it's as close to perfect as it can be for a 40+ year old part. then it might cost me only 200 per bezel.
X2 Very difficult to find good used ones. You have to be at the right place, at the right time. 66 Dart tail lights and headlight bezels are the hardest to find. One year only and they aren't repopped. Good luck. tmm
