from a camper. Had 54 k on clock. No ridge wear.on cylinders.checked standard bore.block line bored, magnifluxed.new cam bearings.hastings rings,10 10 on crank.Clevete 77p bearings.
Crane Energized 272 454 lift cam, 273 adjustable rockersBanna grove rocker shafts,double roller Edelbrock timing set crane Hyd lifters ,new water pump 714 heads teflon valve seals standard valve job Melling oil pump. Changed course going with a 408 striker. Less then 200 miles on build.
Coming from Cali. To Carlisle. Possible delivery depends on time and buyers location. Or pick up at Carlisle next month.. valve covers and intake not included. Avaliable. Separate. Pm any questions.
$ 1,500.00. Crated up ready to go. Currently in San Diego area.
