67 440 engine 6.16.66 casting date
Steersdad
Member
Rating - 0%
0   0   0
67 440 engine with 727 auto and 10" converter.
1967 Mopar 440 (C-engine code) with 4 barrel iron intake. 68 906 heads. Mopar Performance Electronic ignition, Mopar Performance valve covers, aftermarket hydraulic cam (Belive it to be Mopar Performance 284 degree, .484 cam). Taylor wires. New plugs and oil change. New fuel pump and fuel lines. Forged crank.
If you are interested you may come to make a compression test, leakdown, or any other test you'd like. Runs well, 70 psi oil pressure. Includes mini starter.
hear/see it on youtube: you will note 1 leaky Valve cover gasket . six pack seen in video is NOT included. Price includes 4 barrel intake, no carb.
Will strap to a pallet and ship anywhere. Or you can come pick it up. If you are restoring a 67 GTX, RT, Charger, Dart or Cuda, this is for you.
Located in Litchfield, CT. Price reduced to $2,000.00.
I need a 4x4. anybody have a newer 4x4 and want to trade (I'll add $$ as appropriate).
[ame="http://www.youtube.com/watch?v=eupAsoFkdaI&feature=youtu.be"]20120821 195157 - YouTube[/ame]
