[Found!] 67-69 318 timing cover & Timing Pointer
Cover. Think I might have pointer in rental garage.
There's two different ones in those years. They'll interchange, but, if you're after the stock look, the early '68 and older is one type, that uses a bolt on pointer, and the late '68 and '69 type with a cast in pointer.
