[SOLD] 67-72 A body 340/360 motor mounts
moparmat2000
Grand Tetons
Aftermarket 67-72 A body 340/360 motor mounts and grade 8 mounting hardware with washers and lock nuts. Mounts are OEM thickness. NOT made in China. Pix shown on a 1978 360 block. I have 6 pairs of these for sale. $155.05 per pair PayPal friends and family, or $160.50 per pair using paypal goods and services. Price per pair includes shipping anywhere in the USA. Located in West Texas.
Those are nice looking brackets. What company manufactures them? Was it necessary to add washers between the block and one of the brackets to make it fit, or am I seeing that wrong?
Thank you
Bertoni Engineering in Brazil makes these for me. There is a extra washer to shim the LH side of my 360 block. Not sure if all 340/360 blocks are like this or not. That's why the kits have an extra shimming washer in case needed.
Just curious.....what's the advantage of using your brackets over the stock 318 brackets when doing a conversion to a 340/360?
Only if you already have a set of 318 brackets and want to use a 3/4" spacer on the one mounting ear. Otherwise new construction, same thickness as OEM, new grade 8 hardware
Ill
I'll take a set if they will fit a 68 barracuda
Your e mail address has been removed. You will need to exchange that information through a personal message. You can use the "contact seller" button on the first post.
