Hi all,
I am reproducing the heat only controller pins for 67-72 A Body and 69-76 Dodge Truck (May fit other models and years)
These pins are made from aluminum rather than plastic.
2 pins shipped $20.00 US (US addresses only at this time)
(Non US addresses pm me)
I have 4 styles available.
2 have the split top
2 have the post top
In 68 the controller changed for A Bodies, the pin has a thicker center section.
The info provided is believed to be accurate BUT I make no guarantee. If I need to make a change to the info pm me.
1967 A Body and 69-76 Dodge Truck
(BTW...The 69-76 controller is a direct replacement for the 67)
I have both split top and post top. The split top is typical for 67 A Body and post top is typical for 69 to 76 Truck
(The thickness of the center as about 0.100")
1968 to 72 A Body
(The thickness of the center as about 0.200")
Informational Controller Photos
67 A Body heater control (One year only, note the split top pin and Nyloc nut on the center retainer)
69 -76 Dodge Truck heater control (Note the solid post top pin and spring clip center retainer)
68 to 72 A Body heater control (Note the black plastic center retainer and the levers slide vs pivot like on the other controls)
Image from an E bay listing
REBUILT 68-72 Dart A-Body HEATER CONTROL w/KNOBS NON-A/C Duster Demon Heat 69 70 | eBay
If you are in need of other custom / one off repair parts PM me.
If this ad gets "closed" over time I still have the parts for sale, PM me
2 have the post top
1968 to 72 A Body
