[SOLD] 67-76 A body 273 318 left side exhaust manifold $65
gregpurcell
Greg Purcell
Near Savannah, GA
This is a factory A body small block exhaust manifold from a 75-76 318. If you are swapping a 273 or a 318 into a 67-76 A body this piece is a MUST. Many times the a body 318 used the same passenger side manifold as the b and e, but this left side piece was designed to clear the steering column specifically on the a body.
There are about 4 different castings from 67-76 but they will all fit and work. Again THIS is the numbers match for a 75-76 but you can use it back to 67.
Part is in nice shape, cleaned and painted. located in savannah, GA I need to get $65 plus $20 for the ride.
Thanks for looking!
