72 340 DUSTER
i have forsale an AC/heater box assembly from a 1974 plymouth duster, im almost positive that it will fit any air conditioning 67-76 a-body, this heater box is in excellent shape and comes with everysingle peice if you are wanting to convert your non AC car to an AC car you will run into the problem of the heater motor hole in your fire wall not being large enough for the ac motor which bolts from the outside unlike the inside in a non ac car. being that is is an isue i will cut out the original metal from the firewall of my AC parts car so you can fab up your new AC firewall. this is the most complete kit ive seen recently even comes with AC/heater control head. truly everything you need including the below dash vent that is original black in excellent shape w no cracks or broken tabs! i am asking $300 and will cut the firewall if need be, send me a pm if interestead, thanks! i will be posting pictures soon
