[FOR SALE] 67-76 A body Clutch pedal linkage rod $20
gregpurcell
Greg Purcell
Near Savannah, GA
This is a used original clutch linkage rod that goes from the clutch pedal to the Z-bar on a 67-76 A body.
It is 14 1/4 inches long.
This part has been wire wheeled and painted with Cast Blast. It is in good condition.
Note: Brewer's transmission has a very nice reproduction of this part if you would rather have a new one.
Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
If used will do, this one is located in Savannah GA. I'd like to get $20 plus the ride.
Thanks for looking!
Greg
Thanks for looking!
Greg
Greg, I need all parts: A-833 tranny, shift lever, clutch and brake pedals with bracket Trans. must be reworked or good oem. I also need bellhousing, clutch fork, Hurst shifter and everything to make the stick shift work in an automatic car. Can you help some more?
