67-76 dart belt molding interchange ?
ppmopar
SD CALIFORNIA
does anybody know if 67-72 and 72-76 Dart door and quarter panel belt molding is the same? o is it any difference?
Thanks on advance
If you're talking about the moulding that goes along the length of the car and stops just behind the front wheel on my '73 Dart, then it's widely-available universal stuff. It stops there on my '73 because I thought it looked dorky extending all the way forward; your prefs may vary.
I am taking on the belt moldings the ones that are on the top exterior side of the door and quarter panel
just below the glass, right? 4 stainless pieces and a curved pot metal piece at the back. I believe that this is the same for those years but not sure it was available in 67.
Yes the set is 6 pieces total. Because I need it for 70 but is a seller that have a set that came from 75 but I am not sure if fit on 70
as long as they are both 2 door hardtops, you are in luck. If you are worried measure the top of the door and the distance from the front of the quarter to the back of the rear side window and it should be an inch or so shorter than that (for the pot metal piece), and compare to the length of pieces offered for sale. Tip: the original push in clips had a little round gasket that fit down on the original (fairly large) hole. if they aren't there figure out away to seal the holes (not airtight but good enough to keep 90% of the water out).
