67-9 Conv Top Frame Seals
2fine69s
69 340-6pak Rag Top
Elm City, N.C.
Hey guys,
Getting ready to paint and install the top frame on my 69 Dart. I have three sealing areas that I need to address first. The first is I think called a "Retainer Channel" (hope thats right). It has what appears to be an Open Cell gasket on each of these channels and they are not supplied in SoftSeals kit. Anyone know where to get these from? Next is a seal that goes between the header and a plate that attaches to the header with screws. It also has a gasket under it. Any ideas where to get it from? And lastly, it appears there will be a large area between the windshield post and the post molding that will need to be filled with a sealant or caulking of some kind. What do you guys use for that? Here is a pic of the channel. For some reason the program will only let me post one pic, so I'll try to edit and post the others.
Thanks,
Martin
Some of these same weather striping materials can be found in home improvement stores.
