67-9 Dart/Barracuda Vert Trim Clips
Are your clips new? ( Rear deck area)
Yes some are new. Probably should have bought all new. Layson’s have them in stock. Just didn’t make any sense on installing them not pinching the weld but they are on now. Next is trying to locate the clips for the trim on top of doors and quarter window area as pictured. Need about 10 of them at the minimum.
You did put the clips on the lip like this, right?
Only part holding in place is the point going through the pinch weld
The screw passes through the hole in the pinch weld, mine actually make contact slightly. The screw attaches to the clip, the clip straddles the hole, the screw passing through the hole in the pinch weld keeps the trim from coming off.
