67 A-100 van front and rear axle for sale
64X2
Mohel at your service.
kentucky
Rating - 0%
0   0   0
Mopar 8 3/4 67 A-100 van axle 741 case.......$300.00
67 A-100 van straight axle.......$200.00
PM me with contact info if interested.
Thanks Pete
is that the big or small bolt pattern? that should be posi too right?
do you happen to know if the with of the axle assembly is the same as the a body car?
It's wider, the perches are on the top instead of underneath and has the shock mounts welded to the tubes - as seen in the 2nd photo. Not a good candidate! Gears should be at least 3.55 or 3.91s.
It would need to be cut down to fit an A-body.
Stuff still for sale...need money bad...any reasonable offered accepted....
