[WANTED] 67 barracuda A body fastback trunk divider hinge and pattern to build
DIacia
New Member
maryland
Rating - 0%
0   0   0
We are in need of '
67 Barracuda fastback trunk hinge
AND a pattern to build trunk the divider
...sadly both were lost in moving from shop to shop for restoration
Thank you
I used 1/2" plywood for mine.
Some '69 dimensions if it helps....
OA Width (over trim)......
Center height...........
End heights............
Bottom driver side view (top interior face)........
Just a heads-up- the 1967 divider had a double latch (with corresponding header) and 68/69 had a single latch (with corresponding header). The door has metal trim.
Early 67's came with a single latch. Ours did. I replaced orig board 2 years ago. It does have metal trim around the perimeter, altho it doesn't do much.
