I have (2) 1967 Barracuda Fastbacks. One I am restoring and other for parts. Someone had cut holes in inner fenders. I assume for header dumps (Drag Racing)? Anyway, I purchased (2) new inner fenders from AMD. I then started to take measurements of the engine bay, from firewall to radiator support on both sides then the diagonals across the box.
Was I surprised to find as much as 3/8" difference from firewall to radiator support between the driver and passenger fender attachment points and 1/2" difference in the diagonal. This thing is no where near a square! Was this a fluke? I went out and took the same measurements on the parts car. Same thing. I then measured the width between the fender attachments at the firewall then measured the width of the radiator support.
Turns out that the radiator support is narrower that the firewall. So the engine bay is wider at the firewall and tapers down at the radiator support. This still doesn't account for the 1/2" difference in the diagonal measurements.
Does anyone know why the distance from firewall is not the same on both sides and the diagonal measurements are so different? I did check the hood and it is square! Any recommendations? Do I square this thing up or does anyone know why Chrysler did this? A tooling/jig screw up and was easier to make the compartment un-square to fit a mistake in tooling setup??
