noisydart
Member
I looked at the car from the rear and noticed the middle trim piece on the decklid was maybe 1/16th inch higher the both the little matching trim pieces on the taillights. So I pushed down on the trunk lid and it was slightly loose. It is not in danger of flying up, but it rattles. It probably explains why the car rattles back there when I couldn’t find anything loose. How do you adjust it ?
