67 Barracuda Fastback Rear Panel Question
noisydart
Member
los angeles
Have a 67 Fastback. The car came with the left rear panel removed.
Its a triangular panel with a cork type insulation on the back and a thin chrome
trim piece. Problem is there are no fasteners. How does this panel attach? Some
kind of screws and or clips I image.
Any help on what sizes they are, where to get etc. would be appreciated
trim clip
Wanted to add that the metal that the screws would go into has just big holes.
Must be some kind of slip on piece that accepts a screw (?)
The large side panels go in first, don’t recall how many points it makes contact with but there should be slots there, I’m guessing 1/2” #8
Daves69: I believe he is talking about the side panel, not the trunk divider panel.
Noisydart: They are a variety of holes. The small ones take sheet metal screws that secure the side panel. The larger ones are passthroughs for the clips that secure the trim strip.
Press in T-nuts.........
