'67 Barracuda Fastback S 383 4 speed rear end issue?
Manual Transmission & Clutch Discussions
  1. Dennis Jackson
    Dennis Jackson Well-Known Member
    64
    64
    Jun 16, 2020
    Spring Lake, MI
    Local Time:
    6:56 AM
    New owner here, and my questions are piling up. My noob status is quickly becoming apparent, so sorry for that. I think I may have an intermittent problem with the 3.23 sure grip rear end, but I'm not sure, so...
    According to the previous owner, the car has a new McLeod diaphragm style clutch & throw-out bearing, flywheel was resurfaced, clutch linkage was rebuilt, and shifter was upgraded to a Hurst Competition plus conversion from the original inland shifter mechanism, so I'm assuming it is not a clutch issue. I am not aware of any work done to the rear end, so I'm assuming that is original and 53 years old. Here is the symptom as best I can describe it...
    It happened a couple of times on the test drive, and I assumed it was just my inexperience with driving it, but now I am questioning that. When starting from a dead stop in first gear, I get what I can only describe as a severe shuddering of the rear end. It feels like the tires are wanting to spin, but they won't let go and the whole car shakes until i disengage the clutch, give it more throttle, and slowly re-engage the clutch (sometimes a few times) until I get it going smoothly.
    After buying the car and getting a better feel for driving it (I have had it a week), I went a while without a problem, but now it seems to be happening again intermittently. I swear the clutch action feels different when it happens, and I don't think it's me. The clutch action feels 'normal' most of the time and I don't have issues up shifting or down shifting gears 2, 3, or 4. Does this sound like a problem with the drive train or the driver? I have as of yet not intentionally tried to do a burn out. I have been in 'baby it' mode for the most part up to this point. Any sage advice to an admitted greenhorn would be most appreciated. Thanks
  2. Oldmanmopar
    Oldmanmopar Going left turning right FABO Gold Member
    8,423
    4594
    Jan 8, 2009
    Danielsville Pa. 18038
    Local Time:
    6:56 AM
    Does this happen when pulling out around a turn or going straight? Around a turn it could be the clutches in the sure grip which is normal. Just let the clutch fly and drift the turn you won't hear any noises.
    You mentioned it has a diaphragm clutch. Is the large overcenter spring still on the peddle assembly under the dash? It shouldn't be. A diaphragm plate does not need a over center spring. It will be noticable on the engagement on a RPM shift or pulling out .
    • Like Like x 1
    • A56
      A56 MoParAffliction FABO Gold Member
      1,211
      1147
      Jun 24, 2014
      White Oak, N.C.
      Local Time:
      4:56 AM
      Sounds to me as if the clutch is giving you the problem. You could elevate the rear of the car and do some basic investigation.
      • Like Like x 1
      • Agree Agree x 1
      • Dennis Jackson
        64
        64
        Jun 16, 2020
        Spring Lake, MI
        Local Time:
        6:56 AM
        Now that you mention it, it may be happening more on turns, but I would swear it has also happened on a straight away. I will pay more attention going forward and try what you suggested. I looked at the clutch pedal and could not see anything that looks like a spring on the mechanism.
      • A56
        1,211
        1147
        Jun 24, 2014
        White Oak, N.C.
        Local Time:
        4:56 AM
        Well, I would definitely crawl under there sooner than later or have the previous owner informed of your concerns before some nightmare ruins the car and your day. That can only get worse.
        • Thanks! Thanks! x 1
        • ZMan67S
          ZMan67S FABO Gold Member FABO Gold Member
          7,862
          8691
          Jul 25, 2017
          Kansas
          Local Time:
          5:56 AM
          Here is a picture showing its location. Its a good size spring. You have to get under the column and look up for it.
          • Like Like x 1
          • kursplat
            kursplat FABO Gold Member FABO Gold Member
            3,021
            1971
            Aug 24, 2010
            so cal
            Local Time:
            3:56 AM
            it can blend in pretty well, here's a pic of a B body setup for reference
            • Like Like x 1
            • A56
              1,211
              1147
              Jun 24, 2014
              White Oak, N.C.
              Local Time:
              4:56 AM
              There's a thread on here somewhere about clutch adjustment that you may want to visit. Type in "clutch adjustment question" in the search box
              • Dennis Jackson
                64
                64
                Jun 16, 2020
                Spring Lake, MI
                Local Time:
                6:56 AM
                Thanks to you both for the visuals. It definitely does not have the spring installed. I can see the attachment point where the spring would go. I did note however that the spring attachment point is making contact (rubbing against) it's neighbor to the left, the parking brake bracket. It doesn't look like the interaction would ever be enough to block movement of the clutch pedal, but there are definitely metal filings on the outer surface of the clutch spring attachment point.
                • teringer
                  teringer ase master hall of fame
                  809
                  171
                  Feb 22, 2011
                  kenly nc
                  Local Time:
                  5:56 AM
                  you might be getting oil on the clutch and not slipping when hot just grabbing
                  • Like Like x 1
                  • my68barracuda
                    my68barracuda Well-Known Member
                    1,291
                    971
                    Dec 6, 2009
                    Indianapolis IN
                    Local Time:
                    6:56 AM
                    Verify that the motor mount bolts, motor to bell housing to transmission bolts transmission mount bolts are all preset and tight.
                    • Like Like x 1
                    • RedFish
                      RedFish Well-Known Member
                      24,282
                      2873
                      Sep 5, 2007
                      Local Time:
                      5:56 AM
                      Something very simple to try... get a bottle of Fords friction modifier and pour it in the differential. If they've never changed the formula of this stuff, don't spill a drop! Its smell registers right there with a dead skunk. Vapors from the empty bottle would clear the break room.
                      • Like Like x 1
                      • Dennis Jackson
                        64
                        64
                        Jun 16, 2020
                        Spring Lake, MI
                        Local Time:
                        6:56 AM
                        :rofl:
                      • Dennis Jackson
                        64
                        64
                        Jun 16, 2020
                        Spring Lake, MI
                        Local Time:
                        6:56 AM
                        Turns out that my issue was 100% caused by the clutch pedal spring attachment point interacting with the parking brake bracket. It took quite a bit of messing around, but once I got the clutch pedal moving completely freely, it drives like a different car. Not a fan of how much side-to-side play there is in the pedal mechanism and I expect I will be messing with it regularly unless/until I replace it or rebuild it. Anyone have experience with that? Are there suitable replacements available and/or can they be successfully rebuilt?
                      • RedFish
                        24,282
                        2873
                        Sep 5, 2007
                        Local Time:
                        5:56 AM
                        drawing shows there are renewable bushings. Finding new could be a challenge. No guessing if they are all the same size. The bushings at brake pedal weren't. Good luck
                        • Like Like x 1
                        • my68barracuda
                          1,291
                          971
                          Dec 6, 2009
                          Indianapolis IN
                          Local Time:
                          6:56 AM
                          There is a FABO member that makes Replacement bronze bushings for the pedal assemblies. I put a set in mine, a year ago, they are nice pieces.
                          I will try to find his name,,,,
                          • Agree Agree x 1
                          • my68barracuda
                            1,291
                            971
                            Dec 6, 2009
                            Indianapolis IN
                            Local Time:
                            6:56 AM
                            Try ValiantOne for the bushings.
                            • Like Like x 1
                            • my68barracuda
                              1,291
                              971
                              Dec 6, 2009
                              Indianapolis IN
                              Local Time:
                              6:56 AM
                              • Dennis Jackson
                                64
                                64
                                Jun 16, 2020
                                Spring Lake, MI
                                Local Time:
                                6:56 AM
                              • kursplat
                                3,021
                                1971
                                Aug 24, 2010
                                so cal
                                Local Time:
                                3:56 AM
                              • Dennis Jackson
                                64
                                64
                                Jun 16, 2020
                                Spring Lake, MI
                                Local Time:
                                6:56 AM
                                Thanks but he already contacted me. Thinks he can get me some next week.
                              • A56
                                1,211
                                1147
                                Jun 24, 2014
                                White Oak, N.C.
                                Local Time:
                                4:56 AM
                                Is yours full, that happens as well?
                              • A56
                                1,211
                                1147
                                Jun 24, 2014
                                White Oak, N.C.
                                Local Time:
                                4:56 AM
                                Here ya go
                              • Cruze426
                                Cruze426 FABO Gold Member FABO Gold Member
                                149
                                48
                                Mar 11, 2019
                                Illinois
                                Local Time:
                                5:56 AM
                                Don't know why your clutch pedal would move, is the c-clip missing from the shaft? It's on the right or opposite side of the pedal.
                                • Agree Agree x 1
                                • Cruze426
                                  149
                                  48
                                  Mar 11, 2019
                                  Illinois
                                  Local Time:
                                  5:56 AM
                                  It's the lock ring in post # 6.
