67 barracuda fuel gauge
I have restored gauges. It will cost more than a "good luck with it" gauge.
in that case the problem could be a loose nut on the back of the gauge or a problem at the sender.
sender is putting out,will check connections at gauge again. Thanks.Pm me a price for the gauge if you can thanks again.
there is also a harness connector in the left kick panel where the rear harness connects with the dash harness. Make sure the ohm reading your getting from the sender is maintaining to the gauge.
Hello Redfish... I saw that you posted that you have remand factored gauges for a 67 barracuda? I am in need of a fuel gauge. Do you have one to sell?
You would need to send your gauge to me for exchange. Send me a pm if interested.
