Frank
Active Member
I'm looking for a flat hood that will work with a 67 Barracuda. Anyone have any ideas except for the 69 barracuda hood??
69 has a beak and unless you change the header panel and grilles it wont exactly work either. BUT a beak nose dart are nearly the same hood as a 69 B-cuda, The inner structure is different.
I thought the 73-76 Dart Sport Hoods and 69 Cuda hoods were the same??? Not real sure, but someone knows!
sorry - and to answer your question - there are no steel flat hood options for 67-68 barracuda. That I know of...
you will need to go fiberglass. there is a bolt-on version of the same hood listed above from aar. you can use it with window regulator springs since they are a lower tension.
http://www.aarqualityfiberglass.com/products/barracuda-flat-hood-1967-68-bolt
