67 Cuda Rear Tire
SuperStock
Northern Virginia
Hi there,
I have 67 Barracuda, stock rim. I currently have 195/70 R14 .
I would like to put some wide tire in the rear, which tire size do you recommend ?
Thank in advance
Are you going to use the stock rim? If so, do you know how wide it is? If its a 5.5" rim and you plan to re-use it, a 235/60-14 would be as wide as you should go. With different rims you have lots of options.
