67 Dart License Plate Brackets
Darin
Active Member
Land O Lakes, FL
Does anyone have pictures of the front and rear brackets for license plates on a 67 dart?
Also, anyone remaking / selling them?
Thanks,
Darin
Thanks,
Darin
Hmmm....mine just screw into the bumper, front and rear, with those little nylon holders.
Thanks for the reply,
The problem is that those are only on the bottom of the bumper so you can not use any of the license plate frame holders that need the top holes.
Well, here's mine...
I attached the plate to the bumper using the bottom screws, then used small nuts and bolts to attach top of license frame to the license plate.,.....
Thanks 65val, I will do it that way.
For some reason I thought there was a bracket.
Thanks everyone for the help!
Darin
