Hi all
I'm looking for a 67 Dart trunk lock and associated hardware.
I know I can buy reproductions
Here is the rub...
As I understand it.
67 had a unique key way
68 had a different unique keyway
And 69 up had another unique keyway.
There was a Chrysler memo that said if a lock was replaced under warrantee all locks would be replaced with the 69 up style keyway
So I'm looking for a 67 style keyway trunk lock.
This is an "I" key.
Let me know what you have.
It should be presentable and not corroded/rusted
Light scratching on the stainless outer cover is ok
If you think you have what I need I can send you a key to test.
Thanks
Dana
Here is the rub...
As I understand it.
This is an "I" key.
Thanks
Dana
