Can I use a set of 1967 Pulleys and alternator bracket on a 73 Small block with the 73 water pump? Or do I have to change to the Pre 70 water pump? I am just trying to figure out a way to get the Dart running on a budget. Thank you.
By the time you buy the new water pump, the required radiator, hoses, etc. to match your pulleys, your "budget" will be shot.I am just trying to figure out a way to get the Dart running on a budget.
