68 baracuda 340 s
Dave Goetz
Active Member
everett wa
Does any one build a 1 3/4 header that I dont have to cut my wheel wells to install.I recently stroked my 340 to a 408 and the tti stair step header is not enough.
Why wouldn't the TTi step headers be enough? you have 700HP?
TTi step headers are about the biggest you,ll get without cutting your fenderwells.I was in the same boat before the tti,s came out with the step headers.I ended up cutting and using the Hedman Husler 1 7/8 fenderwell headers.Good luck.
TTI has a 1-7/8 header now.
The Super Comps dont work with Milodon iol pans so if you have one your out of luck,
I guess I have to cut the wheel wells after spending many hours and hard earned cash to fix the butcher job done by prevouis owners.I have had extinsive work done on my heads and 1/58 wont couver the ports.Does any one make adapters so I can run tti 1/78 racing head headers our could someone recomend a company that build headers for my situation?
I linked the 1 3/4 headers you asked for in post #7.
They will fit just fine. I had those in my 68 Barracuda.
Here they are again. http://www.summitracing.com/parts/HOK-5204HKR/
