68 B'Cuda
Mopar_Bill
Member
In my house
On a 68 Cuda notchback, what is the widest tire that can be fit in to the stock wheel well with relocated springs?
I have 255/60-15's on the back of mine mounted to 15x8 wheels that have 4.5" of back spacing. I do not have relocated springs and there is about 1/2" of clearance between the tire sidewall and the spring and about 1.5" of clearance to the outer wheel well lip.
A wheel with less back spacing (better centering in the wheel well) would have allowed a 275/60 with no issues.
If you are going to relocate the springs in board of the frame rails then there is a lot of room in the 68 Cuda wheel wells for a much bigger tire.
Ive had 325-50-15s on min. 275-60-15 is a better fit.
heres the 275
