yotah1
As I'm rebuilding the car, i'm trying to make some space in the garage and basement, I hope the prices will be fair.
It all comes from my 68 Cuda, all was running fine.
It is all located in Royal Oak, MI 48073
Shipping can be arranged but if possible I would prefer local pick up in the Detroit area.
Prices are negotiable in a reasonable manner
Happy buying guys, I hope these will help someone else on their car.
Contact here or via PM first, then i can give a call.
Stock piston for a 318 engine, 4 valve recess, with pins and rings : 90$
Automatic transmission pedal assembly (with pads) + parking brake assembly : 25$
904-7.25 driveshaft 2.75"diameter 51.43"length (small U joints) : 40$
original 318 air filter : 15$
Brand new 318 stock diameter valves (1.78" - 1.5") : 150$
original 68 A-904 transmission with linkage (worked fine when i got it out, shifted great) : 150$
Fuel pump : 20$
Fuel pump : 20$
