[WANTED] 68 cuda lower trunk trim clips
572cuda
Active Member
Tennessee
Rating - 0%
0   0   0
I'm in need of 2 clips that hold the lower trunk trim on, I need 1 that goes in the middle which has 2 threaded studs, and 1 that goes on the end which has 1 threaded stud, thanks
if worse comes to worse, you can very carefully, cut the outer(end) ones in half, just make another small bolt to match the stock one, to duplicate. did it on mine, worked out ok!----bob
