68 dart 4 speed tunnel question
hotrodram
tyrone pa
68 dart that was 3 on tree car, coonverting to 4 speed. tunnel was bought out of AMD, see it can basically go 1 way with floor contours. floor cut 1/2 in to the inside of new panel and will spot weld it in. in these pics, does trans cross member look like its in proper position and where would the rods run....on inside or outside of the crossmember piece that bolts in? thanks all! tom
The x member is good. Two of the shift rods 1-2 and 3-4 run above the x member and the reverse rod runs under it
