68 dart front seat
dan brooks
willoughby, Ohio
I have a 68 gts that I bought as a basket case. My question is did a 68 gts come with a front bench seat? I had someone look at the fender tag and they said it looked original to the car but had the numbers for a bench seat. What should the numbers be for a bench versus buckets on the fender tag? Thanks, Dan.
Friend of mine had a 68 GTS converible with bench seat too. Easy way to tell is look under the carpet. Bucket seats got reinforcement plates welded in at inboard bolt holes.
Maybe if you hook up with the GTS registry he can help you out. The fellow on there is pretty knowledgable about GTS's
Daryl
