jeryst
I'm going to look at a 68 GTS that is for sale. I was just wondering it there is anything (Other than the VIN number) that I should look for to make sure that it is a real GTS. Just cant be too careful nowadays.
the gts have the wide rear tail moldings that say dodge. its the same width as the tail lights
and also i believe they also have the cone on the front grill?
There are also numbers under the trunk seal on the drivers side.
The wide tail panel came on the GT's and GTS's
The center cone was an early production option, not just on GTS's It was available on the 68 Darts that was produced in late 67 and was discontinued a few months later. I believe the mold got broke or something like that and they just discontinued it.
The second digit of your Vin will say what model/price class and the 5th digit will say what engine it came with. There should be a Vin decoder on this site to check it out.
Other than the fender tag, you could look for the factory bucket seat brackets welded to the floor, the factory dual exhaust hangers welded to the frame rails, the original holes for the GTS emblems on the fenders and deck lid. I'm not sure about the GTS but the GT's don't have a model emblem on the glove box door like the plain models do.
I don't think the 68 and back cars had a VIN number stamped in them anywhere. I think it was 69 that they started to stamp the VIN number in them, 68 and back had a number that matched the fender tag but not the VIN.
The VIN should have a P or an H as the 5th digit if it`s an authentic GTS. Like some of the guys have already mentioned the 68`s will have the second half of the shipping order number on the last line of the fender tag. 6 digit # (see an example in picture, the # 145038 ). This number should match the number on the left side radiator core support and the left side trunk lip under the gasket. Some of the early 68`s will have the engine and bellhousing stamped with the sequential number of the VIN. This should be just behind the distributor and on the left side edge of the block/bellhousing.
