1968 Dodge Dart
Pro-Street / Race Ready
Color is Viper Metallic Silver with Black Interior.
This beautiful 68 Dart has well over 35k invested.
She now has a newly built 400 based 499 Stroker Engine with less than 100 miles on her. ( Engine details below).
Engine is strong, car is tight and she is fast. Built to run 10s as she sits street or strip!
Car is registered in MA and I have clean title in hand. Passed Inspection and could go either way as a pro-street or all out Drag car. I have driven her very little while working on it and only been to a few local shows. Never raced at Track.
I was very close to having this Dart where I wanted to be but, I have run out of money.
Engine: is a 1972 400HP Block Stroked to 499cid
Block Painted Hemi Orange / Well Detailed
30 over Bore finish honed with deck plates, squared and trued
Line honed and ARP Main Studs
Cleavite Cam Bearings, SS Frost & Galley Plugs
4.150 Stroke Eagle 4340 Chrome Molly Forged Crank micro polished and balanced.
Eagle H Beam Rods 4340 forged & balanced with ARP Rod Bolts
Mahle Forged Pistons balanced 11 to 1 Compression
Childs and Albert file fit Molly Rings
Cleavite H Series Performance Main and Rod Bearings
Mellings HP Oil Pump
Comp Cams Custom 0.550 lift Hydraulic Flat Tappet Dual Pattern
Comp Cams Hydraulic Lifters
Pro-Comp Aluminum Heads w/ SS Valves and Double Springs
Pioneer Dowels and Keys
Pro-Comp 1.6 Ratio Roller Rocker Arms
ARP Cylinder Bolts and Smith Bros Hardened Push Rods
Felpro Gaskets- all
Edelbrock Victor Polished Aluminum Intake Manifold
Mopar Performance Polished Aluminum Valve Covers
MSD Ignition MSD Pro Billet Distrib
Holley 980CFM Carb
Duel Electric Derale HP Fans
Aluminum HiFlow Water Pump
Champion Aluminum 3 Core 26 Radiator
GM 100amp Alternator
Stainless Polished Hoses and much more.
Body: is all steel and rust free solid.
Custom Fiberglass Hemi Hood and fiberglass bumpers.
Paint is very respectable, a few chips but- overall looks great.
Interior still has factory clean dash, nice door panels and clean custom interior.
Comfortable race seats with Cheetah Shifter and line lock setup.
Full set of gauges, Older NHRA certified cage with swing out.
Duel Optima Batteries in Trunk w/ Flamming River ON/OFF kill
Pro Street 15gal Fuel Cell
Drive Train:
Custom Narrowed Dana Rear
Strange Axles 410 gear
Custom 15 Convo Pro Wheels
4 Link Ladder Suspension
QA1 Coil Over Adjustable Shocks
Tubular Upper Arms
Wilwood Disc Brakes All Around
All New Steel Lines
Trans is built 727 Turbo Action 2800 Stall Converter
Cheetah Reverse Manual Shifter
Line Locks NO Trans Brake.
Custom Molly Balanced Drive Shaft w/ Loop
Frame braced and customized for strength
Mickey Thompson ET Street Radials
Skinny Radials upfront
** Giving her away for only 20K Firm ** Please PM
This Dart was and can be financed thru JJ Best
Located just outside Boston MA.
Will assist $$ in transporting if needed.
Felpro Gaskets- all
Holley 980CFM Carb
Drive Train:
Tubular Upper Arms
All New Steel Lines
