68 Fastback courtesy light socket
sydcuda
ALICE SPRINGS, AUSTRALIA
Here's a pic of the courtesy light area on the rear wraparound of my 68 fastback.
I think I'm missing a part here, as the wires you see dont mount directly to the wraparound to accept the bulb - there must be a socket of some kind that fits in here, and to which the wiring is attached and also the bulb.
Am I right? If so, has anyone got a picture of this part so I cant hunt two of them down?
Cheers
That's a good question. A previous owner of my 'Cuda replaced the lights with small speakers and hogged out the hole to do so. I will need to find new fixtures.
I had the same problem, solution:
[email protected]
503-668-7786
I got the entire harness, it came with the gas gauge wire as well.
The plastic is very fragile and I do not think they will take it apart and send just that, but you can certainly ask.
