68 Inland 4-speed shifter
ronw
cashtown,Pa.
Is there a trick to putting the reverse lock out cable aligned to the hole in the lift up finger? Thanks Ron
You new cable should be long enough to work on. But if it just right at the t-handle, do this:
1) Use the stud push the lead ball up, held them on the ground so that the cable come out all the way.
2) Install the t-handle. Hand tighten the lock bold.
3) Lower the stud until the lead ball at desire location - usually ltitle higher than the shitter mouting base. Tighten the lock nut.
Thanks for your help. Ron
