68 vailant 340,4 speed
72duster72
castle rock co.
68 valiant 225 6 CID. Auto. what has been added to car 8 3/4 rear end 3.23 posi, axle new all new suspension (tie rods,bushings,ball joints, lower control arms with sway bar tabs added sway bar) brakes are large bolt pattern front all new disc, rear new 11x2.5 drums. Car runs and drives but I still will consider it a project car body in fair condition no rust (the little rust it had was cut out and new metal welded in) needs interior (gold) dash is perfect. Also included is 4 speed set up almost complete (needs clutch, clutch adjuster.boots.bolts, shifter handle) have everything else and a complete 340 pan to carb 500 miles on rebld. Spec on eng.40 over,kb hyper tech pistons 9-1,cam speed pro 288-298/443-465 214-224 @50,360 heads 2.02-1.60 valves,1.5 roller rockers this is 69 block with forged crank vin says it came out of 69 dart gts,can include 65 gt buckets seats black great condition PM with question. $7,600
If those are the '73-'76 LBP disc brakes in the pictures, shouldn't the brake calipers be towards the front of the car? I know mine are towards the front. Maybe I'm wrong, but I think you got the spindles on the opposite sides of the car than they should be on.
-Ryan
-Ryan
that fine you can do that, the ball joint is centered.
they can go both ways if you put a swaybar they only fit this way. that freaked me out too i saw a dart they where mounted in front ask mopar mach. he said they can go both ways
do you still have the car. if so i sent you a private message with my phone number call me ------ thanks, James
i have couple of guys intrested in the car only get back to me 2-3 days if car sales i will sell motor but not until car sales
