69 A-Body console
72 340 DUSTER
Northern Kentucky
Rating - 0%
0   0   0
Hey guys, i am right now restoring an A-body console out of a 69 dart. it has all the linkage, the shifter and mechanism and i plan to perfectly replicate the factory brackets that weld on the the floor with either the same thickness steel or thicker and throse those in with it, when i am finished it will be repaired in all areas resprayed the corect black, new wood grain inserts, all chrome polished extreamly, rebuilt shift mech with new heavier spring that wont wear out, i have had every bracket linkage and shifter mech sandblasted dupont etch primed dupont reg. primer and sprayed with bare metal paint to try and be correct (not that it matters because you cannot see it) and i will install new legendary black carpet. i have everything ive done photographed and documented so you can be confident in what you are buying. i plann to be done with it in a few weeks and will then post many detailed pictures and a very descriptive ad, i just wanted to go ahead and put the bug in everyones ear to see if anyones interestead, i would like to get $350 for it when it is completed, let me know what you guys think please,
Go MOPARS!!!
