TD Charlie
Member
the other issue is the unsightly CD player that was put in. I took it out today and the wiring was just as bad as the hack job to fit it into the dash. My options here are to buy the Redondo HU, and a whole new bezel, or try to plastic fill where the stock trim originally was...orrrr just a radio delete. The car is far too loud to hear the radio anyway, I’m leaning a radio delete.
if you’re still with me here, any thoughts? I think leaving the wood on the upper bezel, peeling it off the bottom, plastic filling the cd and Krylon chrome spraying it is best. I’m not sure how reasonably successful i can be with it. As for gauges i am totally lost. Not to mention i can’t get this trim out. Aside from visible screws what needs to be pulled? Light switch/lighter/heat control? I’m so afraid to snap something
thanks for listening!
