Looking for the headlight mount ring for the passenger side of a 69 Barracuda. Hopefully someone has a unusable fender this piece can be removed from.
Picture below shows a 68 version that was grafted for repair on my original. The whole assembly was replaced up to the part line on the top mounting flange.
I need the correct ring (only) as shown in the yellow circle from a 69 that has had the spots cut for removal as (shown in the red circles), or a trash fender/Bucket section that I can remove one from. The correct mount ring (Driver side) is shown in the second picture and has the brackets (circled in green) required to mount the eybrow trim ring.
