69 barracuda wheel/tire combo
broughj
Member
I have a 69 barracuda with stock SBP disk on front and SBP rear with springs in stock location. ET wheels makes a 5 spoke wheel in SBP that I'm about to pull the trigger on. I'm thinking of a 16 x 7 front wheel with 3 1/2" backspacing running a 205/60R16 tire. On the back I'm thinking of using a 16x8 with 4" backspacing running a 255/50R16 tire. Any thoughts/opinions on how this combo might fit?
I have same size tires but on 15" rims. just fit, l think 16"s would be too close to the srings and wheelwell edge, depends on your back spacing on you wheels
How about a link to where you found sbp ET wheels ?
I'd like to check them out !
Do you have a pic ?
I have the small bolt pattern also. Just curious if the 16X8 with the 4" backspacing and 255/50/16 will work?
