69 cuda carpet question
rjsam
On a 69 cuda fastback does the back of the trunk divider and the trunk area have carpet on them? Thanks for the help
No. The back of the drop down divider has a thick flat black surface on it (I would say paint, but it has almost a different texture then paint- kinda like a smooth bedliner material). The trunk has a rubber mat with a printed on pattern. In my case, the mat is gray and black plaid. There is suppose to be a horsehair type pad under the mat on both sides of the hardboard tire cover which helps to bring the rubber pad up a little more level.
