69 cuda reverse light repair
qkcuda
Jarvis, Ontario
A while ago someone was looking for reverse light screws for a 69 cuda. I said I planned on using nutserts as the holes in my valance were stripped. One of my reverse lights had been hit at some point, and although the housing was intact it dented the valance and broke the glass lens. I finally got around to making the repairs on the weekend, and the nutsert idea worked out great. The original screws had a very small head to seat in the bezel without contacting the glass lens. I bought 10-24 machine screws and just ground off the edges for clearance. Turns out I ended up with two right side bezels so I have not completed the install but the test fit went fine.
Couple holes in my 67 valance are somewhat stripped as well. They would "snug up" somewhat.
I ended up using those little plastic tabs that are on the machine screws when you buy a outlet or switch for the home. Its temporary but holds them.
Proper screws aren't available?
Nice work on yours!
I do have two original screws. The other two had been replaced by larger diameter wood or sheetmetal screws when the original screws stripped the hole. This is a nice permanent fix which is totally hidden by the housings.
Finally after more than 10 years I have working back up lights. The repair worked out great.
I sent my original screws to Sammy. I used stainless machine screws of the same type with painted black heads, but just put E or U clip/nuts, however you describe them, in to accept the machine screw. Nutserts would work fine as well.
