[WANTED] 69 Dart 340 GTS Radiator
69DARTWANTED
Wisconsin
I've discovered the radiator in my Dart is too small for the #'s matching 340 in the car. Does anyone have a 340 Radiator....I believe 22 inches wide for the 69 Dart?
Does the GTS have a special radiator for the 340 cars?
I don't need the exact year/production code....just looking for the stock appearance Vs. a aluminum.
Anybody know what year radiators will all fit the 69 dart?
Thanks,
Will
I think i jave one from a 69 340 dart, Least that is what i was told. If someone can verify the numbers on it.
Can you verify what numbers you have on that radiator? Is it 22 inches wide?
What kind of $ would you be thinking about?
Not Quite sure what this came from but was told a 340.
I think that's a 70 up radiator. 69 down has the round top.
I"m pretty sure you're right. I'm told the round top radiator is stock on the 69 dart.
Anybody know if a GTS is the same as any other 69 dart regarding the radiator part number?
all 69 340's without AC running a manual or automatic had the rounded upper radiator tank with the number ending in 066. If not mistaken AC cars had a number ending in 065 but not 100% sure on that part.
Most have a opinion on the correct part number and some do know what is what. Then again Mopar may have put what ever was on the rack in the car as it went down the assy line. My 69 340 Dart has rad # 2949069 in it. So go figure. Find a good clean rad as big as you can put it in the car and drive it like you stole it. Any 340 in a A body is fun to drive and sound's cool !!!!!
:blob::blob:
Still looking for a Radiator for a 69 340. This is the round top style with the stamping: 2949066
Let me know if anybody out there has one for sale.
Thanks!
This is what you are looking for if you have not seen them before. From my 69 340 4 speed Barracuda.
I have a set of upper and lower tanks and the sides that require a new core if interested.
This is the rad you are looking for. From my 69 340 4 speed Barracuda.
I have a spare set of upper and lower tanks as well as the sides that need a core. Great shape. PM me if interested.
