ssba
Wanting to sell a dart project I've had for 10 years to speed up one of my other projects.
This is not a driving car and will need more parts than I have to finish but I will list what I
can remember.
The quarter panels have been opened up to super stock templates. Springs moved into rails.
Dana 60 35 spline power loc with strange axles. 4.10 gears. 1350 yoke & truck driveshaft.
Inner wells moved to rails.
23 spline 4-speed, Lakewood bell, aluminum 130 tooth flywheel, mopar performance lightweight starter,nos scheifer clutch, Hurst shifter complete with linkage rods. Vintage red ball reverse lock out. Complete 4-speed conversion pedals hump z bar etc. Poly thru bolt transmount & cross member.
Hooker fender well headers and collectors ,2 chamber flow masters, no pipe.
Manual steering, Dc k member nice home built from small block k. Poly spool mounts., all new Moog suspension parts including pitman, idler & 11/16 tie rod ends and sleeves. Big bolt pattern 11 3/4" rotors.
Polished vintage slot mag wheels 15x11" rear 15x3 1/2" front new lugs & caps. Mickey Thompson sportsmans frt and rear with new tubes. Very nice matched set.
Superior 500 steering wheel and adaptor, new dash pad, Stewart warner mechanical tach,
A-100 seats no rips nice, new vfn Hemi scoop, new tail light lens& bezels.
440-1 aluminum heads, t&d rockers, push rods, 65 aluminum Hemi water pump housing with milodon pump, milodon aluminum oil pump, dual line swinging pickup & pan, remote filters.
2 Holley blue pumps & fram canister filter. Electronic tach drive race distributor, cables rev limiter& splitter for tach. 440 & 4-speed are dated 69. This car will need more welding such as driver front pan lower rear quarters and subframe connectors not included. No bodywork has been done just some of the welding.
That's all I could remember right now, I will add more later and try to get some pictures up if I can figure out how. If this sparks an interest please pm me. I will not break any of this up. 1 car 1 price. I will total up what I have invested and see where it goes. I hate to guess at this time.
I will likely need help with posting pictures.
Great site by the way. I don't post much but read others post every day.
can remember.
