I have conflicting views on weather the space in between the raised chrome ridges on a 69 Dart Dash bezels are suppose to be chromed or is this strip suppose to be painted silver? Can someone shed some light on this?
I'll check when I get home tonight. Seem to remember the space between the ridges on my 'ol '69 Dart were black. I'll check and post later.
OK, here's the scoop - I'm currently working on a '69 Dart project to kinda recreate the Dart I had years ago that I cut to make a racecar (stupid) and later sold (stupider). My project started as a Dart 270 and the dash bezel trim is silver between the two ridges on most of the bezel. The area on the bottom of the bezel where the labels for the controls are is black with white lettering. Hope this helps.I'll check when I get home tonight. Seem to remember the space between the ridges on my 'ol '69 Dart were black. I'll check and post later.
I won't be using my stock trim as I'm upgrading to a Rocky Mountain Dashes full length panel.
Best of luck with getting resolution to your problem issue.
Im not sure if these are the same but look to be chrome
http://www.gcartrim.com/Dodge Dart.htm#66-69 Dart
Ive had some work done by this guys and its top notch!
