69 dart disc brakes conv.
rm69dart
Costa Mesa, Calif.
hey guys i have 73-74 spindles and upper arms, i am installing on my 69 dart and a friend gave me some 11 inch rotors and calipers all new i think rotors are for a roadrunner or charger. is it possible to do this? looks like the bracket for the calipers is to small. is there a larger bracket?
Yes, the caliper adapters from a larger car, 77-? Cordoba, Charger, Road Runner will allow you to use the larger Rotors. There are 2 different systems, Pin and Slider, you probably have the slider system. The adapter brackets from "C" bodies may also work. Mopar Action has a tech article on line for this swap and gives adapter info as I recall.
